Set project-level user permissions in Amplitude Experiment
Experiment project-level permissions enable Amplitude admins to manage access to Experiment separately from Analytics permissions. Use this when you want to:
  • Prevent analytics team members from releasing features through Experiment, and/or
  • Prevent product development team members from affecting data taxonomy, or key dashboards and charts in Analytics, while
  • Allowing all team members to keep higher permission levels in their primary apps.
Note
Setting project-level user permissions in Experiment is only available to Growth or Enterprise customers.
To set project-level user permissions in Experiment
  1. In Experiment, click Permissions. The Experiment Permissions page displays, with the Joined Users tab open.
  2. In the Search field, type the name or email of the user you're looking for. Then, click the checkbox next to their name. The actions above the table should now be selectable in blue.
  3. Click Manage Project Access to search for the project where you want to adjust permissions.
  4. From the dropdown displaying the current permission level for the selected user, select their updated access level. Then click Next.
  5. If you're sure you want to make these changes, click Submit.
Flag-level access controls
With flag-level access controls, you can decide which Experiment users can make changes to specific flags or experiments.
When flag-level access controls are enabled, users in your organization can't save changes to restricted flags and experiments unless they're specifically designated as an editor for it.
Default access for new flags and experiments
You can set the default access for new flags and experiments to a restricted list of editors, or all users in your organization.
This is controlled by a organization-wide setting. Go to Experiment > Permissions > Organization Settings to access the setting.
Only users with the admin role can modify this setting.
The default sets new flags and experiments as editable by all users in your organization. If you create a new flag or experiment, you can manually restrict access to that item after you create it.
If you change the default and make new flags and experiments viewable instead of editable, only editors can modify new flags and experiments. Remove this restriction after you create the flag or experiment.
If you create a flag or experiment through the Management API, it defaults to editable regardless of the organization setting.
Managing access to flags and experiments
To edit the list of approved editors, navigate to [flag or experiment] > More Actions > Manage Access. From here, you can add individual users, or specify that the flag is editable by all users in your organization.
After you grant a user editor permissions to your flag, Amplitude Experiment checks permissions and verifies that user 's role has edit access. For example, if you assign a user the viewer role and later add them as an editor to your flag, they can't save changes until you give them a role with editing privileges.
Users get a notification when you add them as an editor to a flag or experiment. You can control your notification settings by going to Personal settings > Notifications > Updates about my experiments
Bypassing access restrictions
There are two ways to to make modifications to a restricted flag or experiment when no editor users are available:
  1. Admin users can edit restricted flags and experiments, even if they aren't on the list of editors.
  2. Use the management API to edit all flags and experiments, regardless of the item's restricted access.
Permissions matrix
This table describes the various permissions included with each permission level.
Role-based Access Controls (RBAC)
For Enterprise organizations with Role-based Access Controls (RBAC) enabled, review the available Experiment Roles and Permissions.
Viewer Member Manager (Project) Admin (Org)
Deployments Read Read/Write Read/Write Read/Write
Activate Read Read/Write Read/Write Read/Write
Variants Read Read/Write Read/Write Read/Write
Allocation Read Read/Write Read/Write Read/Write
Analysis Read Read/Write Read/Write Read/Write
Metrics Read Read/Write Read/Write Read/Write
Experiments and Flags Viewer Member Manager (Project) Admin (Org)
Read Y Y Y Y
Create Y Y Y
Edit Y Y Y
Delete Y Y Y
Deployments Viewer Member Manager (Project) Admin (Org)
Read Y Y Y Y
Create Y Y Y
Edit Y Y Y
Delete Y Y Y
Mutual Exclusion Groups Viewer Member Manager (Project) Admin (Org)
Read Y Y Y Y
Create Y Y Y
Edit Y Y Y
Delete Y Y Y
Users Viewer Member Manager (Project) Admin (Org)
Add user to a project Y Y
Edit project role Y Y
Add user to organization Y
Edit organization role Y
Other Viewer Member Manager (Project) Admin (Org)
View Project API Key Y Y Y Y
Was this page helpful?
July 11th, 2024
Need help? Contact Support
Visit Amplitude.com
